API 675 CONTROLLED-VOLUME DIAPHRAGM PUMPS
DO YOU HAVE A FORMULA TO CALCULATE THE BHP OF API 675 PUMPS IF SO PLEASE ALSO TELL ME THE REFERENCE
Thank you
Aamiree
RE: API 675 CONTROLLED-VOLUME DIAPHRAGM PUMPS
Is it not the same as for any other PD pump, just adjusted for pumping efficiency?
SNORGY is right. It is the pump's required power not considering volumetric efficiencies. Brake horsepower is a term which is applicable to any kind of pump.
