API 6A, Material Qualification to Temperature Class X
Hi Guys,
I have several sizes of square blocks and round bars which I want to use for the production of API 6A Flanges and Blocks. The original MTC does not qualify the material for elevated temperature use. I want to use these raw materials for the manufacturing parts which comply to Temperature Classification X.
As per my understanding, I will have to cut additional testing specimens from the available material and perform elevated temperature testing on them. This will include Tensile Test and Impact Test.
Question: Can a part manufacturer do this additional testing to qualify the material?
Question: If yes, I do not have the TC and QTC for this testing, I am using the finished product to extract the test coupons. Is this allowed? and how many test coupons should I take for each heat number?
Question: If I am allowed to use the finished product for testing, I am confused about the ER method. How do I apply it to the finished product?
Any guidance in this regard will be more than appreciated.
RE: API 6A, Material Qualification to Temperature Class X
Have you read API 6A Annex G and API TR 6AF1?
