slam model in etabs
slam model in etabs
hello to all my friends pls. help me how do i model rib slab and solid slab in etabs? membrane? shell or plate? im a noob when it comes to structural concerns.. i need to learn but i have a hard time for this. my only mentor for now is eng-tips.com and you all guys.
RE: slam model in etabs
Alternatively, you can model each part of the slab as area elements with the real thickness, which will apparently make your model more complex.
Membranes can be used directly, as you can choose this type from the Define->Area Sections.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
wish you all the best
