local extrema
local extrema
local extrema
Hello everybody!
I am trying to determine and plot the local extrema (min(max) and max(min)) for the signal y=x.*w with x(400:1424)=sin(2*pi*t) and w(400:1424)=sin(52*pi*t).
I am using matlab 2010b with the following script:
clc
clear all
Fs=1024;
t = 0:1/Fs:1;
x=zeros(1,1824);
w=zeros(1,1824);
vm=1;vc=2
x(400:1424)=sin(2*pi*t);
w(400:1424)=sin(52*pi*t);
y=x.*w;
figure(1);
plot(y); hold on;
Is there anyone with an idea how to accomplish this?
RE: local extrema
The min(max) is the minimum of the local maximum when you use a slide window on a signal. Max(min) is the opposite: the maximum of the local minimum.
It creates the upper envelope and lower envelope of the signal.
RE: local extrema
I was a bit confused by your use of indexing, but maybe this will get you started?
CODE --> MATLAB
f   = inline(vectorize('sin(w1*t)*sin(w2*t)'),'t','w1','w2');
df  = inline(vectorize('w1*cos(w1*t)*sin(w2*t)+w2*sin(w1*t)*cos(w2*t)'),...
             't','w1','w2');
ww1 = 2*pi;
ww2 = 52*pi;
tmin= 0; tmax= 1;
inc  = 0.01; k=1;
t = [tmin, tmin+inc];   %Set initial search range
while t(1) <= tmax
    % Check for sign change within search range
    A = sign(df(t(1),ww1,ww2));
    B = sign(df(t(2),ww1,ww2));
    if A~=B % If sign change, find where derivative equals zero
        tt(k) = fzero(@(t) df(t,ww1,ww2), t);
        k     = k+1;
        t     = [t(2), t(2)+inc];
    else
        t(2)=t(2)+inc;  % If no sign change, increase search field
    end
end
Link to image
