Black steel pipe, sch 40 !
Can someone tell the difference between the following and whether both can be used for chilled water piping system as per codes.
1. Black Steel Pipe Sch 40, seamless, Grade B (ASTM A 53)
2. Black Steel Pipe Sch 40, ERW, Grade B (ASTM A53)
RE: Black steel pipe, sch 40 !
What code.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
rmw
Where are you located and what Codes are you building this to (for example, do you have to meet NFPA Code?)
Can you be more specific, it's not the issue about sizes. It's about knowing the exact specs of a carbon steel pipe that one should use for these systems. I am located in middle east.
Some don't like ERW pipe below 2" NPS because they do not believe that adequate weld soundness testing can be properly accomplished at the smaller sizes. But for a Category D service most are not that fussy.
I personally would not buy A53 ERW from China at any size due to wide reports of problems with Chinese origin material of that type.
Either of the materials that you propose are acceptable for this service. Here are a couple of specifications for above grade chilled water pipe systems.
http://www.gsa.gov/portal/content/101297
http://www.iu.edu/~uao/15510.pdf
