insert the custom properties txt file?
Vb script
hello
macro or vb script, import and insert the custom properties in part, starting from a txt file.???
hello
RE: insert the custom properties txt file?
You mean user defined properties ? How is looking your text file ?
Check also CATIA Portable Script Center, if I remember correctly, it is an example there (or few?).
Fernando
https://picasaweb.google.com/102257836106335725208
Ferdo
insert in catpart user custom properties, with a txt file.
exemplo
menu-editar-product-define othrer properties - external properties
load the txt file, myproperties.txt.
This file has properties defined for other catparts
I have a macro to insert the properties,
insert txt file loads the properties filled
is possible with one catscript or catvba??
I do not know how to start.
thank you
Yes, is possible. You have to read in your macro line by line your txt file, set user parameters and values to them and write in User Defined Properties.
The only problem is your txt file to have always the same format, so you can read it correct in your macro. In that chm file you have an example how to write to a txt file, you can adapt to how to read from a txt, then put all together with your macro to insert properties.
If you still have problems, post your code here so we could help you.
Fernando
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set product1 = partDocument1.GetItem("")
Set parameters1 = product1.UserRefProperties
Set strParam1 = parameters1.CreateString("teste01", "")
strParam1.ValuateFromString "testando1"
Set product1 = product1.ReferenceProduct
End Sub
I use this to enter a new property, then ok
txt file to insert not know
I do not know vb program. about macro in Catia
I can help,
thank you
Look at the code bellow, is a CATScript
Sub CATMain()
Dim partDocument1 As PartDocument
Dim part1 As Part
Dim parameters1 As Parameters
Set part1 = partDocument1.Part
Set parameters1 = part1.Parameters
Set product1 = partDocument1.GetItem(part1.Name)
Set parameters2 = product1.UserRefProperties
'~ ’Create Userproperties
Set strParam1 = parameters2.CreateString("MyUserProperty", "Hello Guys")
part1.update
End Sub
This was an example how user defined properties can be created (only one parameter). As far as I know, when importing a txt file, you will have same result like creating few user defined properties.
So, the idea is to read the text file line by line in macro, get from there the user properties and the values one by one from each line ( for example MyUserProperty2 and "Hello Guys 2" a.s.o.), then write them in strParam2 , strParam3.....
To read from a text file you can do it somehow like (pseudo code):
Const ForReading = 1, ForWriting = 2
Dim fso, MyFile
Set fso = CreateObject("Scripting.FileSystemObject")
Set MyFile = fso.OpenTextFile("C:\temp\User_Parameter.txt", ForReading)
Do While MyFile.AtEndOfLine=false
ReadLineTextFile = MyFile.ReadLine
'''here you need write your code
Loop
Fernando
Ferdo,
I'm learning, Vbscript
write the code, post here when ready
thank you,
ferdo,
look at the code,
Sub CATMain ()
Set product1 = partDocument1.GetItem ("")
Set oCATIAFileSys = CATIA.FileSystem
Set oFile = oCATIAFileSys.GetFile (sDocPath & "C: \ Users \ Eddy and Sarah \ Documents \ Projects \ VBScript \ 123.txt")
Set oTextSteam oFile.OpenAsTextStream = ("ForReading")
Oline = oTextSteam.ReadLine
Set strparam1 parameters1.CreateString = ("", "")
strparam1.Value = oline
strparam1.Rename "Edcarlos01"
Set strparam2 parameters2.CreateString = ("", "")
strparam2.Value = oline
strparam2.Rename "Edcarlos02"
end Sub
what do you think? can get better,
have to set the txt file. create and rename the parameters in macro
the property value import txt file
Take a look here, you can use some lines to improve your code
Fernando
I am ok to create userrefproperties, but how could you remove a userrefproperties that is already created in the doc ?? For example, i have a part with a userrefproperties called "TEST" and i want to remove it via a macro (in order to make a recursive loop on all a produxt)
Thank you
