600V oscilloscopes
600V oscilloscopes
hello we have an algient 3000 scope and it only takes 300V rms.
any suggestions for a 4 channel scope that I can use on 480V circuits.
Maybe something that can compute THD% and have current probes for displacement power factor and total power factor?
any suggestions are apprecaited.
thank you for your time and have a good day
RE: 600V oscilloscopes
I had a Fluke 190-204, but it didn't work well. And had very limited memory. Which it used to lose now and then, very frustrating. So I sent it back and am now living happily with this blue beauty. Yes, it is blue. And it is a beauty.
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
We have the similar model of an oscilloscope with same color and feelings .We were little disappointed when we have worked in recorder mode because it can only work with a DC signals .Do you have any of the additional units e.g. measuring ampere pliers
For current clamps, I use several different types. From heavy pre-historic ones to Fluke and Chauvin&Arnoux lighter ones. I also use several budget clamps, like APPA, which are OK if you need to record several DC currents and can't afford four of the more expensive types.
I am also waitng for delivery of a current clamp with Bluetooth. That will make recording directly to my laptop a reality also in noisy environments.
Gunnar Englund
www.gke.org
