Replaced component not visible
I'm having this problem already for a long time. As long as I can remember actually.
When I replace a component the new component is not shown in the graphic window. I can see it is replaced in the assembly navigator, the "block" is also yellow and toggled on.
"unhide all" does not work.
The only way to get them back is toggle them off and on again. Or move to another window and go back to the part again.
With big assemblies this is very annoying. Is there easier way to make them show up again?
Regards, Michel
Regards, Michel
I use NX7.5.4.4
HP Z600 Intel Xeon E5520 2.27GHz Dual
9GB Memory
Windows 7, 64-bit
Groeten, Michel
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
RE: Replaced component not visible
I use NX7.5.4.4
9GB Memory
Windows 7, 64-bit
Groeten, Michel
Check that you use the certified driver, or if you do, try changing the settings of the driver, try things like "VSYNC Forced off" etc.
Tomas
