Lanotech Heavy Duty Liquid Lanolin
I would like to seek advice on the following product “Lanotech Heavy Duty Liquid Lanolin”
The product is going to be used as a lubricant/corrosion inhibitor for a number of components located on an offshore facility. The plan is to use the product as part of a routine maintenance regime on a number of valves and actuators offshore. For example if any areas of the valve (stem/gland area, body, spool piece etc) are found to be corroded, we plan on using this product to prevent or reduce the progression of corrosion in the short-term, until the valve/actuator assembly can be taken offline and repaired properly.
Just want to get peoples opinion on the suitability of this product or whether they would suggest an alternative?
Cheers,
