PWHT
PWHT
I would like some help in determining the necessity of PWHT because I didn't understand very well the paragraph UW-40(f)(5)(d) about determining the nominal thickness of groove+fillet weld.
The groove design is similar to that in figure UW-16.1 (y-1).
The weld is between a head and the nozzle neck.
The thickness of the head is 32 mm and the thickness of the nozzle neck is 106 mm, should I consider the nominal thickness equals to thickness of the head (depth of the groove) + fillet weld throat dimension or should I compare them and use the thicker one?
To calculate the holding time at the PWHT temperature and the heating and cooling taxes should I use this nominal thickness or should I use the thickness of the thicker part, in this case, the thickness of the nozzle neck?
Thanks!!
Thanks!!
RE: PWHT
RE: PWHT
RE: PWHT
In your opinion, in this case what part of the welded joint should be considered as the nominal thickness? The head thickness, because it's a full penetration joint?
RE: PWHT
