Pro Intralink read only files
We just started using Intralink (3 months), I have imported all files. My question is that I imported this one assembly that had a family table of 4 instances, it worked fine, then another user made another instance and checked it in. The problem is if I try to check out this assembly now the new instance is read only and will not let me check it out (unless logged on as admim), but the other instances are ok. Has anybody seen this before and how can I remove read only attribute?
Toff
Toff
RE: Pro Intralink read only files
This family table Item... are the Instances all in the same folder?... are they all the same release level?... Does the logon you use have access to the folder the instance is in, and release level it is on?...
Daniel Pro/E Specialist
http://www.torgon.com/
Toff
Maybe I have to set up these forms?
Toff
