View labels customization
Is it possible to customize view labels? I work in SW 2012.
I know you can edit it when view is inserted, with manual view label option selected. I would like to have them permanently set in our language. I can't define custom label under document properties. Is there maybe a format file like it exists for bend notes (bendnoteformat.txt) so you can customize them. I can't seem to find it for view labels.
RE: View labels customization
I found out that 2013 version has new option in document properties for setting custom view labels, so we will get it with upgrade, but until then I would like to set it in 2012 version.
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
You should be able to dock your German Labels onto the current English View Label so they are attached with 2012. You can use a German Installed version and the customization settings will still work. I've used Pro/E in Japanese lang and had no trouble. the icons will still be the same, not sure about menu ordering but I believe that would be the same as the english version as well.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
You looking to have specific languages applied to labels, or simply able to choose names from various languages?
Matt Lorono, CSWP
Personal sites:
