Weathering steel poles - Transmission lines
Hello there,
Is that possible transmission tower line poles fabricated with weathering steel to be corroded?
I have pictures but I don't know how to insert here. I understand that Cu and Cr added into regular steel to make weathering steel.
These poles have large isolated marking on the surface which appears washed away paint.
If this corrosion what are the causes it happens? a quick response would be greatly appreciated.
RE: Weathering steel poles - Transmission lines
http://en.wikipedia.org/wiki/Weathering_steel
If these had been mishandled in fabrication, transport, or erection the result could be accelerated localized corrosion.
Plymouth Tube
As the esteemed members have mentioned - typical problems are salt or ponded water.
