Measuring angular deviations of an object submersed in fuel using accelerometers
Dear all,
I have a project that i am working on where i need to measure the tilt/angle of an object at high pump speeds over 6000rpm. I was wondering if anybody had any experience of using a wireless accelerometer to dynamically measure angle. And also has to be located in fluid medium and so would need to be prevented from getting wet.
RE: Measuring angular deviations of an object submersed in fuel using accelerometers
Why not a tilt sensor instead of an accelerometer?
Double post.
Ted
RVDT?
Please don't double post. If you absolutely feel that you have to, provide a link to your other thread, so that everyone knows that you have two posts and only replies in one spot. In this case, you have received good responses in thread404-334286: Measuring angular deviations of an object submersed in fuel using accelerometers. People thinking of posting here would want to know the advice you already received before they spent time responding to you.
