Move Component Tracker Boxes
Hello just a quick question:
When using the move component command (dynamic move), is it possible to turn off the XYZ co-ordinate and distance/snap tracker boxes? Or at least lock them elsewhere on screen?
Also, is it possible to attach a picture to these posts i.e. a screenshot showing what I'm talking about?
Thanks in advance, Carl
RE: Move Component Tracker Boxes
No, not permanent off. You can hide temporarily by pressing "F3" ( try press F3 multiple times to see how it works.)
You can attach pictures in two ways, the simple is to select the link " ...or upload your file to ENGINEERING.com" below the input box. The more difficult but more elegant is to insert a link to the picture, which then must exist on some web server somewhere else. there is a button above the input field "Picture".
Tomas
Thanks Thomas, that works for the XYZ location tracker which helps.
It doesn't seem to affect the distance/angle tracker when dragging handles, presumably we are stuck with that one.
Also thank you for the upload information, I'll keep that!
Regards, Carl
