Dynamic analysis with DIgSILENT Power Factory
I've got a problem with the dynamic analysis in DIgSILENT Power Factory.
I've got a single network system which consist of a 10-kV-busbar with a generator and a load.
The active power of the generator is 9 MW and the power factor is 0,95.
The active power of the load is 5 MW and the power factor is 0,85.
The load flow calculation of this single network system converges.
Now I want to control the active power of the generator with a proportional controller.
In this example the proportional factor of the controller should be 5 and the
active power of the generator should be the input signal of the controller.
My question is, how can I place the active power of the generator as an input signal to
the proportional controller and how can I parameterize the proportional factor of the
controller.
Thank you for your help.
Best regards,
PowerFactoryNewcomer
controller.
Best regards,
