Check-mate check specific components of an assembly
Hello fellow engineers!
Is it possible to create checks in check-mate/knowledge fusion that only perform checks of certain components of an assembly? For example if I have an assembly consisting of 3 parts that follow the following naming pattern: Plate, strut and pin. Would it then be possible to have a checker that checks let's say "sketch fully constrained" but ONLY performs the check for the plate and strut parts?
Thank you
RE: Check-mate check specific components of an assembly
Anyone? :)
I my rather basic knowledge on Checkmate, the only options one has to select what parts to run the tests on are the options visible in the dialog. See attached image. But since the Checkmate seems to be built on Knowledge Fusion, it would not surprise me if one could customize the file selection as well.
Tomas
Thank you Tomas.
I see what you mean. However the best thing for me was if i could somehow edit/create a custom checker that always chooses only some specific features from a part, based on the features names for example.
