Pumpable refractory insulation for older HRSG
Has anyone used or experience with Kaowool Pumpable insultation?
I have three, 20 year old Heat Recovery Steam Generators with numerous hot spots. Many of the hot spots are in inexcessable areas.
Thank You
Thank You
RE: Pumpable refractory insulation for older HRSG
When you say inaccessible, do you mean internally, externally or both?
Externall access is for the most part un-restricted.
I am able to drill through the outer casing wall (or cut through if need be).
Are these hotspots that have just developed over time or what is causing them if your liners are all in good shape?
