Compressed air
Compressed air
Compressed air
I was wondering if there was a spreadsheet that will allow me to calculate, Based on Initial pressure, pipe size, and pipe length, what will be the actual flow in SCFM at the end of that pipe, at standard temps?
RE: Compressed air
Dear noground,
You can try 1) Panhandle formula,where you insert the values
            2) Download the calculation part of www.b3pe.com
If you require details ,I will be glad to furnish.
Best Wishes
Whylie
wahasan@yahoo.ca
RE: Compressed air
Purchase the Crane #410 Technical Guideline.(try AMAZON)... It has the information that you need in tabular form.
also try www.freecalc.com
MJC
RE: Compressed air
Free, on-line Compressed Air Systems information for your plant hourly employees.
Help them understand things better, just go to http://web.wt.net/~gecofact/cas.htm
Written to be easily understood by any new hire.
RE: Compressed air
See the website and order free software for compressed air systems. Helps you optimize your existing systems. great tool and it's FREE! see it at www.oit.doe.gov/bestpractices/
You can call to get it free at 1-800-862-2086 (US customers only)
