Gap between dimension and dimension line
why with standard tolerance, the gap is OK, but when I use ISO tolerance the gap increment ?
I tried to put the gap to zero, but nothing.
Solution ?
Thank you...
Using NX 8 and TC9.1
RE: Gap between dimension and dimension line
When you say gap, it's the distance between the "dimension text" and the dimension line you mean ?
I had a look and i get the same behavior. I think it's a case for GTAC.
Tomas
Adde to GTAC.
Each response will be added here for all NX user.
Thank you...
If we didn't expect that you may need to manipulate the settings we wouldn't have given you access to them winky smile
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Create a new style, save it and you are all set for the next time.
Ben Loosli
John,
when I say that I don't like to manipulate the setting, I intend in this case.
Why if I put the ± 0.1 tolerance in the dimension the result is OK, but if I put the ISO tolerance, the result is different ?
Tolerance are bottom aligned to the dimension text ? If yes, why ISO tolerance increase the distance between the "dimension text" and the dimension line without editing style dimension setting ?
Thank you...
Hi looslib,
the style is OK for all situation.
Only when I add ISO tolerance, this strange behavior require to me edit style dimension.
I don't like.
Thank you...
