Abaqus exited with errors
Hello all,
I am using abaqus on HPCC. The abaqus jobs always stop in the middle, and some files are lost. But I cannot find any error in the .dat file and .sta file. Also, I am sure that the run time has not exceeded the HPCC run time limit (48 hours). So what I am trying to do is to stop the job by myself and abckup all the files, then restart the job. I do not know if it works, and I do not think this is a good way although it may work. Have someone had this experience before? How did you solve it? Thank you very much!
Sincerely,
Jingan
RE: Abaqus exited with errors
Excuse me, what is HPCC?
maybe you are running a high level model or so, but 48 h seems a lot to me.
I guess you can not make a simpler model right?
maybe just trying to run it with a super coarse mesh and check if the errors appear, and when checked, try it with better mesh?
sorry I cannot suggest you something in the way you would like.
n3l3,
Thank you. And it's a cluster.
IceBreakerSours,
Thank you. I tried some simpler models, and they worked fine. I noticed the first 48 hours was fine, but after that when I restarted the job, it would stop without error. Anyway, I will try more times and see if I can find something.
IceBreakerSours,
I checked the .dat file and .sta file, but both of them did not show any error. The license set up is ok, and also the simpler model works fine. I guess I will not use the complex models, just use the simpler ones. Thanks anyway.
