How search item to copy?
Hi Again
Here it´s my code for read holes and thread, and show them in a worksheet of Excel
Sub export()
Dim partdocument1 As Document
Set partdocument1 = CATIA.ActiveDocument
Dim part1 As part
Set part1 = partdocument1.part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
Dim selection1 As Selection
Set selection1 = CATIA.ActiveDocument.Selection
Dim i
selection1.Clear
For i = 1 To shapes1.Count
selection1.Add shapes1.Item(i)
Next
Dim xSelObj() As Variant
Dim xObj As Variant
Dim n As Integer
Dim myObj As AnyObject
Dim nCount As Integer
nCount = 0
For n = 0 To shapes1.Count
On Error Resume Next
Set myObj = selection1.FindObject("CATIAHole")
ReDim Preserve xSelObj(nCount)
Set xSelObj(nCount) = myObj
nCount = nCount + 1
Next
Dim sList As String
Dim nI As Integer
For nI = 0 To nCount - 3
Dim referenceX As Reference
Set referenceX = part1.CreateReferenceFromObject(xSelObj(nI))
Next
part1.Update
Dim Excel As Object
Dim Sheets As Object
Dim Sheet As Object
Set Excel = GetObject(, "EXCEL.Application")
If Err.Number <> 0 Then
Err.Clear
Set Excel = CreateObject("EXCEL.Application")
Else
Err.Clear
MsgBox "Please note you have to close Excel", vbCritical
Exit Sub
End If
Excel.Visible = True
Dim workbooks
Dim myworkbook
Dim myworksheet
Set workbooks = Excel.Application.workbooks
Set myworkbook = Excel.workbooks.Add
Set myworksheet = Excel.ActiveWorkbook.Add
Set myworksheet = Excel.Sheets.Add
Excel.Cells(1, 4) = "diameter"
Excel.Cells(1, 5) = "thread"
Dim iAnzahlGew
selection1.Search "CATPrtSearch.Hole.Threaded=TRUE,all"
iAnzahlGew = selection1.Count
Dim valor As Integer
valor = 0
Dim Hole
For i = 1 To iAnzahlGew
Set Hole = selection1.Item2(i).Value
Excel.Cells(1 + i, 4) = Hole.Diameter.Value
Excel.Cells(1 + i, 5) = Hole.HoleThreadDescription.Value
valor = valor + 1
Next
If valor > 1 Then
valor = valor - 1
End If
Excel.Cells(3 + valor, 1) = "Holes"
Excel.Cells(2, 3) = selection1.Count ' numero de roscas
Dim iHoleInSelection
iHoleInSelection = True
Dim oPartDoc
Dim OBody
Set oPartDoc = CATIA.ActiveDocument
Set OBody = oPartDoc.part.Bodies.Item("PartBody")
Set selection1 = oPartDoc.Selection
selection1.Search "(Name=PartBody* & CATPrtSearch.BodyFeature),all"
Dim selection2
Set selection2 = oPartDoc.Selection
selection2.Search "CATPrtSearch.Hole.Threaded=FALSE,all"
For i = 1 To selection2.Count
Dim oHole
Dim oHoleName
Dim oHoleType
Set oHole = selection2.Item(i).Value
Set oHoleName = selection2.Item(i).Value
Set oHoleType = selection2.Item(i).Value
Excel.Cells(2 + valor + i, 4) = CStr(oHole.Diameter.Value)
Excel.Cells(2 + valor + i, 5) = CStr(oHoleName.Name)
Next
End Sub
Please, someone can you show me how read the circullar or rectangullar pattern, and how obtain the number of item to copy of each pattern?
Sub export()
Dim part1 As part
Dim body1 As Body
Dim i
selection1.Clear
Next
Dim xObj As Variant
Dim n As Integer
nCount = 0
nCount = nCount + 1
Next
Dim sList As String
Dim nI As Integer
Next
part1.Update
Dim Excel As Object
Dim Sheet As Object
Err.Clear
Else
Err.Clear
Exit Sub
End If
Dim workbooks
Dim myworkbook
Dim myworksheet
Dim iAnzahlGew
valor = 0
Dim Hole
valor = valor + 1
Next
If valor > 1 Then
valor = valor - 1
End If
Dim oPartDoc
Dim OBody
Dim selection2
Dim oHole
Dim oHoleName
Dim oHoleType
Next
End Sub
