Vertical Bends in Sewer Force Main
I have an existing (in-place) pipe that must be used as a casing for a new force main. The existing pipe is 20 feet below the roadway. The current plans show two vertical bends after coming out of the casing in order to get the force main back up to workable grade, where the pipe laying would continue for the duration of the force main alignment. I guess I feel like it would be better to gradually make up that grade rather than doing so with vertical 90's. However, gradually making up 20 feet of grade would require some distance of deep sewer laying, that I'm not sure other site constraints would allow. What are your thoughts on the inclusion of the two vertical 90's to bring the force main back up?
RE: Vertical Bends in Sewer Force Main
Richard A. Cornelius, P.E.
WWW.amlinereast.com
But back to your original question, 45s will be as good as sweeping in a curve.
For example, what is the fluid velocity? Velocity if important if you have vertical pipe segments that may trap air. You may need a velocity of 3.5-4 ft/sec to push an air bubble downstream if the pipe direction is verical.
If PVC and you do use fitings; restraints are important. Not only on the fittings; but, also on the carrier pipe within your casing and potentially your vertical risers. You don't want the pipe to push apart in the casing and you have no friction to rely on inside the casing.
However, the smaller the bend angles are, the less will be the minor (head) losses, and if applicable pumping costs forevermore as a result of same. The lighter, and at least maybe some less costly will be the fittings as the angle reduces. Very small angle bends can also result in relatively small pressure and flow-induced thrust force resultants, whereas thrust forces and effects at larger bends like 90's can be huge. When thrust forces are huge, larger thrust blocks or more restrained joints are required, perhaps further increasing overall construction costs. Finally, if anyone ever wants to run anything other than fluid (or anybody) through a pipeline, it may be easier traversed with gradual slopes than with 90's and vertical risers.
What's your problem with using 2 90s? If your concerned about the size of thrust blocks use flanged fittings? The difference in head loss through 45s or 90s is not going to be worth losing sleep over. Do the numbers.
Use 2 90s and get on with life.
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
Ill withhold the word "useless" and just say that your post wasn't very helpful. Not that i expect all responses to be helpful, but it also seemed to carry a tone that suggested you might be a person who is surrounded by people telling you how smart you are. If I were more concerned with your opinion I might argue that it's not the same sewage. I think instead, I'll get on with life.
