"Eggsactly" - A Bioengineering opportunity
Some time ago (2000) I was working on the heatless drying of and aqua ammonia production from layer hen manure for Moark Developments, Neosho, Missouri for fertilizer applications. They have been working on a variety of green energy sources and high tech separations for things like collagen production from eggshell membranes. I was considering a flash freezing operation under high vacuum in an autogenous pulverizer inside of a classifying cyclone for this.
One of you was interested in the use of waste egg matter and they would be a good client to consider for the Bioengineering development of waste products from eggs and manure.
RE: "Eggsactly" - A Bioengineering opportunity
Did you try Search (between Forum and FAQs)?
Good luck,
Latexman
No, as I am new here and not yet familar with the system.
You should be able to find the old thread you spoke of.
Good luck,
Latexman
It was closed
So you saw the one that "was interested in the use of waste egg matter and they would be a good client to consider for the Bioengineering development of waste products from eggs and manure"? I thought that was the point of THIS post. If so, go to his profile and see if they are still active. If they are, give a shout out.
Good luck,
Latexman
