how much heat is required?
Hi, I am doing a room temperature control system. The box dim are 30cm long, 25cm wide and 25cm deep. Can anyone tell me how much heat is required to raise the room temperature from 20° to 100°. The reason why I’m doing this is to pick my Darlington transistors which will be switching a 80w paltier cooler.
Thank you.
Thank you.
RE: how much heat is required?
If all you're doing is raising the temperature, why do you need a Peltier cooler? Why not just a resistor bank?
btw. I suggest you find an ME with thermal experience; my rough calc says that your Peltier cooler is too small by about a factor of 4.
TTFN
>>>>>>>>These fora should not be used to bypass your own in-depth research on the issues that affect you, nor is it intended to be a substitute for appropriate professional assistance within your field or geographical region.>>>>>>>>>>>
