Catalytic Converter Design
Hi all,
I would like to analyze the flow of gases that enter the catalytic converter using Solidworks flow simulation software. Can someone help me how to calculate the mass flow rate and CFM of the exhaust gases? We use engines with turbo chargers.
As I am beginner in this field, it would be of great help if you can provide the reasonable assumption I need to make on temperature, pressure velocity of the gases. Thanks in advance
- Praneeth
- Praneeth
RE: Catalytic Converter Design
http://www.eng-tips.com/viewthread.cfm?qid=104735
Thanks for the reply, I have gone throught the post it is all about gas engines with no turbocharges, and I am dealing with diesel engines with turbochargers.... can you please let me know the related posts??
-Sai Praneeth
