Datum on a Spline, Automation Error Help
I am writing a program which will go into an assembly part, and place a Datum on a spline, which will be brought in with one of the assembly components.
I am manually selecting the spline, and I am having the following error:
NXOpen.NXException:Internal error: memory access violation
at NXOpen.Section.AddToSection(SelectionIntentRule[] rules, NXObject seed, NXObject startConnector, NXObject endConnector, Point3d helpPoint, Mode featureMOde, Boolean chainWithinFeature)
at select_a_spline.Main()
The code is as follows
CODE -->
If (SelectSpline(spline1) = Selection.Response.ObjectSelected) Then
         datumPlaneBuilder1 = workPart.Features.CreateDatumPlaneBuilder(nullFeatures_Feature)
         unit1 = CType(workPart.UnitCollection.FindObject("MilliMeter"), Unit)
         plane1 = datumPlaneBuilder1.GetPlane()
         section2 = workPart.Sections.CreateSection(0.02413, 0.0254, 0.5)
         expression2 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
         plane1.SetUpdateOption(SmartObject.UpdateOption.WithinModeling)
         curves1(0) = spline1
         'SplinePoint = New Point3d( 0, 0, 0 )
         helpPoint2 = New Point3d(-2.36825229556759e-005, 0.0, 1124.15035257941)
         curveDumbRule1 = workPart.ScRuleFactory.CreateRuleCurveDumb(curves1)
         rules1(0) = curveDumbRule1
         'section2.AllowSelfIntersection(False)
         section2.AddToSection(rules1, spline1, nullNXObject, nullNXObject, helpPoint2, Section.Mode.Create, False)
         geom1(0) = section2
         plane1.SetMethod(PlaneTypes.MethodType.Frenet)
         plane1.SetGeometry(geom1)
         plane1.ReplaceExpression(expression2)
         plane1.SetFrenetSubtype(PlaneTypes.FrenetSubtype.Tangent)
         plane1.SetReverseSection(False)
         plane1.SetAlternate(PlaneTypes.AlternateType.One)
         plane1.SetPercent(False)
         plane1.SetExpression("2000")
         plane1.Evaluate()
         flip1 = plane1.Flip
         feature3 = datumPlaneBuilder1.CommitFeature()
         datumPlane1 = datumPlaneFeature1.DatumPlane
         datumPlane1.SetReverseSection(False)
         datumPlaneBuilder1.Destroy()
I think the problem is with the section2.AddToSection, but I've been fighting it for several days and have not been able to resolve the issue.
Any help would be greatly appreciated.
RE: Datum on a Spline, Automation Error Help
The error message seems to indicate that you are getting an exception in your select_a_spline function. If not, make sure all the objects are valid by printing out some information before section2.AddToSection.
Suresh
www.technisites.com.au
