Auxview2-filters
Auxview2-filters
Hey there
I've got a session with 30+ models passively loaded in.
This is to create a GA.
I'm looking to filter some of the parts using AUXVIEW2-Filter. But have no idea how it works.
Any helpful info would be most helpful.
Rory
Rory
RE: Auxview2-filters
2. AUXVIEW2-USE-ACTIONS-FILTER
3. PROCESS toolbox appears. There are fiter tools. Only the filters that you can apply to current view are active.
There are three basic filter tools
- selected element won't be projected
- selected element won't be sectionded (only available in section views)
- selected element's hidden lines are removed
reversal actions are available after you have applied a basic filter.
Select filter that you want to use.
4. Select 3d (or 2d) elements that you want to filter.
I think selecting from 3D session is easier. Selected (3d) elements are shown on green color.
You may want to set AUXVIEW2-DEFAULT-UPDATE to MANUAL before filtering. Otherwise view is updated after every selected element and makes filtering process very slow.
That was exactly the info i needed.
Rory
