Type Test Report
Type Test Report
Type Test Report
I would like to ask do you guys accept the type test report to represent a equipment with same concept design but with minor changes such as rated operating frequency, different Type Test according the standard ( such as normally practice are IECs, but they provided IEEE standard ).
RE: Type Test Report
Depending on what you are testing the change in frequency could be quite significant.
Which equipment affected the design significant ?
In my opinion, mainly, motors-induction, synchronous- generators and cables. But also switchgear and other.
Hmm, I would like to know the switchgear, I thought switchgear can be operated in multiple frequency to fullfill international market, perhaps manufacturer design according to the IEEE or IEC.
For instance: for Power Frequency Withstand Test the supply power has to be at rated voltage and rated frequency.See
IEC 60694/60298 for instance.
