Heat Capacity of Bitumen
Hi everyone,
I'm looking for some help with a project which involves using steam to raise the temperature of bitumen in a pump.
I'm struggling to find any information on the heat capacity of bitumen and some other heat transfer info.
Can anyone tell me the following:
Melt point?
Heat Capacity?
Viscosity at room temp. and melt point?
Shear thinning stress?
Any help that you can offer is much appreciated!
Thanks very much.
RE: Heat Capacity of Bitumen
Inadvertently I pressed submit post, before I finished the message. There are three viscosity levels for bitumen grades:
•Maximum pumping viscosity = 2000 centistokes [cSt]
•Mixing viscosity = 150-300 cSt
•Spraying viscosity = 50-200 cSt
These viscosities vary with temperatures.
Good luck.
