Workbnech 14 - One Component, Multiple Materials
I am using Workbench 14 to model a simple cylinder with a large precipitate embedded within the primary matrix. I have separate material profiles for the matrix and precipitate set up in Engineering Data. How do I apply those different properties to different parts of the cylinder in my model? In MAPDL I recall I could set up separate profiles for elements using different material properties and choose which element to use for a given portion of the mesh. Is there a similar functionality in Workbench 14?
