Distribution losses allocation to Distributed Generators
Hello everyone,
Nowadays I am dealing with the following problem.
Assume an MV connection meshed grid with known configuration and technical characteristics, connecting many distributed generators through a unique "exit" at one bay of an MV/HV substation.
We are metering the energy produced at each generation output (locally) as well as the energy flowing out of the connection grid at the substation level i.e at the connection grid's exit.
We know thus the total active energy losses for a time period L (kWh) of the connection grid knowing the energy at the grid exit (i.e. at the substation MV bay) and subtracting the sum of all generators' active energy output.
I would like to allocate a part of above L to each generator so as to calculate and bill the "net" energy produced instead of the "gross" active energy of each generator.
I am looking for a practical if approximate way of doing this (on an hourly or daily basis), not necessarily one that provides the exact theoretical solution to the problem.
Any ideas?
Any ideas?
RE: Distribution losses allocation to Distributed Generators
Any other suggestion?
Bill
"Why not the best?"
Jimmy Carter
