thread162-244410
thread162-244410
thread162-244410: Storm water calculations and continuity - STORMCAD
StormCAD does not use hydrographs. It is a peak flow analysis model using standard step methodology for HGL/EGL. It is possible to get less flow downstream due to the longer "system" Tc's.
RE: thread162-244410
Do you realize you are replying to/resurecting posts that are months and even years old? (this one is from 2009).
