does angone know how to select inner nodes on a 3D model?
Hi, I am analysing the force on an inner section of a 3D cubic model, does anyone know how to choose the node on this surface
RE: does angone know how to select inner nodes on a 3D model?
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
1. Mesh module => Mesh -> "create Mesh part"
2. With the "object" being "Part", Mesh -> Edit -> Element -> Delete
3. Delete elements above or below the surface you want.
4. Create the surface and give it a convenient name like xxxxxxxx
5. Write the inp, open the INP, search for xxxxxxxx
6. Copy the elset and surface definitions, and paste them in the original INP.
There may be a way to do this in CAE (check the CAE manual) but I don't know of it.
