Sort patterns
Sort patterns
Hello again
Apparently I feel bored with this topic, but I would like to finish my script correctly. I´m sorry
Initially I have a Part, which have some Holes and some Thread, there are also some Rectangullar Pattern and Circular Pattern.
My script can read Holes and Thread, give me your Diameter, also can read number of Rectangular Pattern and Circular Pattern
My problem is when I want to read the copies created by Pattern.
I try sel.search all patterns and in this part aplly itemtocopy, but for me it´s impossible that the script give me any number of item to copy....
someone could show me the way?
If necessary I can write the script
RE: Sort patterns
RE: Sort patterns
I like when someone is insistent to solve a problem but I don't like when don't read with more attention what others are trying to tell.
In this post lukaszsz told you something about itemtocopy . Did you checked in documentation what does it mean?
And did you tried, really, to understand what he wanted to suggest you? I suppose not quite really....look bellow what he wanted to suggest (code in CATScript, you have to modify to your needs, I've put more message boxes just to show how you can get more information)
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "CATPrtSearch.Pattern,all"
For i=1 To selection1.Count
msgbox selection1.item(i).value.name
Set objSelected = selection1.Item(1).Value
MsgBox objSelected.Parent.Name
Msgbox objSelected.itemtocopy.name
MsgBox objSelected.Parent.Parent.Name
Next
End Sub
Now, coming to parameters, you can get all parameters in a CATPart with code bellow (again CATScript). If you want only for holes, you have to adapt.
Language="VBSCRIPT"
Sub CATMain()
Dim catDoc As PartDocument
Dim catPart As Part
Set catDoc=CATIA.ActiveDocument
Set catPart=catDoc.Part
Set objParameters = catPart.Parameters
' Loop on parameters to retrieve them
For I = 1 To objParameters.Count
Set objParameter = objParameters.Item(I)
strParmName = objParameter.Name
strParmValue = objParameter.ValueAsString
MsgBox strParmName & " " & strParmValue
Next
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
RE: Sort patterns
I understand you message, I´m sorry if I am so heavy with this topic.
I search item to copy in v5automation.chm, and I only find text about how write the word in my script. Also I search item to copy in Visual Basic program VB --> Edit --> Object browser and search pattern, where I find the word parent about item to copy and itemtocopy.name, itemtocopy.parent ...
My problem start when I try to write this reference in my script, I don´t get work it.
I appreciate your script FERDO, but I can not fix my problem, and I really study the code. I guess my knowledge of Visual Basic are basic. Anyway, when I study your Script I find a path that can help me whit this " Number in dir 1" Of rectangular Pattern, and "Angular Number" of Circular Pattern, this words should show me the numbers of copy of my object in any pattern that I search with the script. I only need search the way of write this path in my code
I will work with this far as it goes.
Anyway a lot of thanks for your help, and I´m sorry if seems that I can´t try to learn and study about your messages, I do it because this is a very important thing for me.
Thank you again
RE: Sort patterns
Understood.
Indeed, now you have to search "between lines" how to solve your problem, what you wrote is a good starting point.
If you work with catvba (vba editor) you have to go in Tools-References and tick CATIA libraries that are referring to the workbench that you need (Part design or Product or whatever you need).
My codes are working in CATScript, I didn't test them in catvba, I suppose they are working if you are loading libraries and adapt the language (if necessary).
Fernando
RE: Sort patterns
I have a few days study caav5. I believe that I am near the solution, but don´t find it yet.
My study:
In circullar pattern, the solution should be:
Properties--> catInstancesandAngularSpacing-->AngularRepartition.InstanceCount.Value
In Rectangular Pattern, te solution shoul be:
Properties-->catInstancesandSpacing--> ?
I try the script:
Sub setinstanceangularspacing()
Dim i
For i = 1 To selection1.Count
MsgBox selection1.Item(i).Value.Name
Dim objSelected
Dim circularpattern
'--->Doesn´t work
'Set circularpattern = selection1.Item(1).Value
'MsgBox CatCircularPatternParameters.catInstancesandAngularSpacing
'--->Doesn´t work
'MsgBox objSelected.AngularRepartition.InstanceCount.Value --> Doesn´t work
'----> Work but don´t show me the instances copy of my main body
MsgBox catUnequalAngularSpacing
MsgBox catCompleteCrown
MsgBox catInstancesandAngularSpacing
Next
End Sub
Thank if anybody know the solution
RE: Sort patterns
CAA is a very expensive license, few big companies have this.
Good for you that you have access to it but I don't believe what you can do in CAA can be done in a simple script.
Fernando
RE: Sort patterns
I can not get to know the number of copies to make a pattern?
I believe that this should be instancecount.value....
because in the example of help show this:
' Purpose: Changes pattern description
' Assumptions: Looks for CAAPriChangePattern.htm in the DocView
' Author:
' Languages: VBScript
' Locales: English
' CATIA Level: V5R14
Sub CATMain()
Dim oPartDocument As PartDocument
Dim oPart As Part
Dim oSelection As Selection
Dim InputObjectType(0) As String
Dim oStatus as String
Dim oCircularPattern as CircPattern
' Get the part document
Set oPartDocument = CATIA.ActiveDocument
' Get the part
Set oPart = oPartDocument.Part
' Get the selection
Set oSelection = oPartDocument.Selection
' Set the selection type
InputObjectType(0) = "CircPattern"
' Get the status
oStatus = oSelection.SelectElement2 ( InputObjectType, "Select a circular pattern", True )
' Get the object in the selection
Set oCircularPattern = oSelection.Item(1).Value
' Set the circular pattern instance number
oCircularPattern.AngularRepartition.InstancesCount.Value = 6
' Set the circular pattern instance as Unequal Angular Spacing mode
oCircularPattern.CircularPatternParameters = catUnequalAngularSpacing
oCircularPattern.SetUnequalStep 6
' Set the circular pattern Unequal Angular Spacing
oCircularPattern.SetInstanceAngularSpacing 2, 30.000000
oCircularPattern.SetInstanceAngularSpacing 3, 75.000000
oCircularPattern.SetInstanceAngularSpacing 4, 75.000000
oCircularPattern.SetInstanceAngularSpacing 5, 30.000000
oCircularPattern.SetInstanceAngularSpacing 6, 75.000000
' Update the part
oPart.Update
End Sub
I thought it was near to the solution..
Another topic
I Believe there was a confussion, i have caav5 visual basic help downland to internet, I don´t have a special license, therefore my script is a simple code write in visual basic editor of catia v5 r20
Thanks Ferdo anyway, your help is invaluable
RE: Sort patterns
I have it
Sub numberofpattern()
Dim oPart As Part
Dim oStatus As String
Dim oCircularPattern As CircPattern
Dim TheMeasurable As Measurable
Dim TheSPAWorkbench As Workbench
InputObjectType(0) = "AnyObject"
Dim oSelection
Set oSelection = CATIA.ActiveDocument.Selection
oSelection.Clear
oStatus = oSelection.SelectElement2(InputObjectType, "Select a circular pattern", True)
MsgBox (oCircularPattern.angularrepartition.InstancesCount.Value)
End Sub
Now I have to find the rectangular pattern variable
RE: Sort patterns
Fernando
RE: Sort patterns
