WELDING GRADE BPIPE WITHE API X-42 ISOLATION JOINT
we had a wall thikness loss due to corrosion on an isolation joint at 6in oil line (6in 600lb,astm A-106 grade-B pipe is used), we need to replace the faild isolating joint and we do not have the same line mat, all we have is API5l x42 isolating jointS, is it possible to weld A-106 GR-B PIPE WITHE API 5L X-42 ISOLATION JOINT
RE: WELDING GRADE BPIPE WITHE API X-42 ISOLATION JOINT
