Help with li-ion PCM
Hi, I had to replace the li-ion battery in a portable device. I have the unprotected battery and proper PCM (protection circuit module).
The PCM wiring is pretty straightforward as you can see by the pics. I have Battery + and - and power (load)+ and - but there is one more terminal on the PCM and it is labeled 'T'. I dont know what this is or if I even need it for this application. The original PCM (bad) and battery only had batt in and power (load).
The PCM is from Hauwei HB5F1, The battery is unprotected 3,7v 1800mah and the device is a rechargeable gas detector.
NOTE:I dont know if the pics uploaded right (may have to copy and paste url ,1 st one tells the story)
Question: Does anyone know what the terminal 'T" is and if I even need it.
Thanks!
RE: Help with li-ion PCM
Probably a temperature sensor. If you have a rapid charge capability you will need to monitor the temperature. If you use a trickle charger then maybe not.
I suspect temperature as well.
-AK2DM
"It's the questions that drive us"
Thanks Scotty!
If it is a temp sensor then I dont need to use it at all as the original pcm did not have this 'T' connection.
I messaged the distributor, he says it goes to ground (?). I am kind of leary of this because my battery negative also goes to ground. Maybe ground at some other point???.
I have fabricated the battery connections (soldering springscannon. I think I may just try and skip it.
I mean, what's the worse that could happenflame
