Avoid or Hide a gridline in a Tabularnote ( in Titleblock)
Hi
I have to start up to set some drafttemplates incl titleblocks.
I have studied some of NX´s orginal template´s ....
I have one question to someone here - if she/he knows it.
In a tabular note - how can a "gridline" between two cell´s be hidden or deleted ?
I need this , just as the attached example from NX default templates.
lklo
lklo
RE: Avoid or Hide a gridline in a Tabularnote ( in Titleblock)
Gary Bangs
www.flowserve.com
Thank´s it works - I had earlier tried this method , without luck.
I am little bit confused because , if I select a cell that already has one border invisible , and then selecet edit style, the parameter from this cell is not inherited in the setting dialog,
it is always SOLID and NORMAL.
But I found out just set parameter to desired setting ,and the border changed.. OK .....but I think there is a small failure in NX 8 here.
lklo
