Broad-Crested Weir Information Pop-up
Can you disable the "Weir coefficients will be updated as you change the breadth." pop-up?
RE: Broad-Crested Weir Information Pop-up
The message appears once whenever you change the breadth, but there is currently no way to disable the message. Unless you changing the breadth frequently, this shouldn't be an issue.
Peter Smart
HydroCAD Software
www.hydrocad.net
thanks - usually not an issue. i was just playing around with different values & wondered if there was a way to disable it. thanks for the quick reply as always!
We should be able to add a "Do not show this message again" option in the next build
Peter Smart
HydroCAD Software
www.hydrocad.net
cool - thanks!
In the latest HydroCAD-10 build 9, there is a "do not show this message again" option.
Peter Smart
HydroCAD Software
www.hydrocad.net
nice! thanks, Peter
