is there a sketch inspector in NX
NX6.0.5.3
I was curious to know if there is a sketch inspector which can be run to make sure there are no overlapping or discontinuous curves.. Many times when constraining gets more tighter , there is a possibility of curves crisscrossing each other or may be a overlapping or dis jointed.
It would be good to have a sketch inspector to run and make highlight any such conditions and suggest options to correct the same.
RE: is there a sketch inspector in NX
Tomas
