Special Inspections Testing for high strength bolts
What are the requirements for special inspections of high strength bolts?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Special Inspections Testing for high strength bolts
The IBC is published every three years. The first edition was published in 2000. The latest edition is the 2012 one. So, JAE is correct; IBC-10 does not exist.
The 2012 IBC Section 2204.2 (not 2205.2) refers to Section 1705 for special inspection of HSBs. Section 1705.2.1 directs one to AISC 360 (360-10) for special inspection of structural steel (structural steel welding and HSBs). Chapter N covers QC and QA. Special inspection tasks are considered QA. Tables N5.6-1 through N5.6-3 covers inspection tasks which are to be performed prior to, during, and after bolting. In previous editions of the IBC, Section 1704.3 contained special inspections tasks for steel (welding and bolting). Table 1704.3 had a column for applicable sections from referenced standards like the RCSC spec for HSBs.
Check this thread http://www.eng-tips.com/viewthread.cfm?qid=317995
