DOF Springs orientation
the DOF spring property card doesn't have an option to choose a Coordinate System.
How do you define stiffness's in a particular orientation?
I've tried defining node output CSys, but I'm not sure if this is right.
W
RE: DOF Springs orientation
if you can't define a element CID or a nodal CID then wouldn't that leave the global CID as the default ?
i guess so, but what defines the DOF spring stiffness orientation then? is it the nodes definition CSys? or is it the nodes output Csys? each node can be defined in a different CSys, it can get confusing.
the dof spring propert card controls how the freedoms at each node are connected.
a simple x spring would connect x1 with x2.
looks like global axes ... runa test to verify ?
does this mean I am locked in global CSys?
no you could use mulitple elements, each presenting a component
or use the damper/spring element which is a CBUSH and allows local CID references
