Extremum Point
Extremum Point
Extremum Point
I'm on Catia V5R19 and can't find the extremum point command. Was it moved to a different toolbar (used to be on point type flyout toolbar)or eliminated?
RE: Extremum Point
GSD workbench
incase the icon bar is gone check Insert --> Wireframe --> Extremum
Win XP64
R20SP7/21SP5, 3DVIA Composer 2013, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
RE: Extremum Point
DBezaire,
I thought so too, and looked there too. Please see attached screenshot!
Is it only included on a different license? I didn't think so because before we upgraded to R19 I know I had it.
If this is the case and it isn't in R19 what is a good way to accomplish the same end result?
Thoughts? Thanks for your help btw!
RE: Extremum Point
Your license would be the same from previous versions to R19. Did you load the GSD module. I think it would be called GSD -- Generative Shape Design 2 for the individual module or you could load the package HD2 which would have it there too.
Is it in tools options general license list?
I am not sure how you would get a consistent accurate result without the option. Perhaps you could create an extruded surface then use a reflect line to get the extreme curve. Intersect the curve with a plane through the original curve to get a point.
Derek
Win XP64
Dell T7400 16GB Ram
