calculate motor power in cooling tower
how much motor power (kW) required in cooling tower, if i have data in these following:
cooling capacity = 2 tons
sump basin capacity = 1.6 meter cubic
flowrate = 0,5 meter cubic per hour
RE: calculate motor power in cooling tower
I probably left out a couple of things.
The very easiest way is to pick up the phone and call a cooling tower manufacturer. Marley, for example, will do all that for you.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
