how to save any list APDL command?
Hi all,
I am working on a APDL file. I want to save the MPLIST (material properties) and load step summary from modal analysis (SET,List) automatically as txt files. I am trying to use
/OUTPUT, MPLIST, txt
MPLIST,ALL,,,EVLT
/OUTPUT
a text file is saved in directory but it is empty :( ... Please help me with
Thanks in advance :)
RE: how to save any list APDL command?
Try to issue the *vwrite command before /output. This should write the data you want into the file. Check ANSYS help for the sintax.
Hugo Silva
Mechanical Eng. PhD student
Materials Eng. MSc.
Don't think that will work Hugo. I think the problem lies elsewhere, I'm guessing that the material either hasnt been defined correctly or is possibly in a table format. The following should definitely work if materials have been defined correctly:
/prep7
/output,materials,txt
mplis
/out
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
