Operating near end of curve
Hello experts,
The scenario is this:
The BEP flow of the pump is near the end of curve(pump run-out condition).The pump is operating 108% from BEP which makes it very near to the end of curve. It has a considerable amount of NPSH margin of 8 feet. Is this kind of pump acceptable? If not, please state some reasons and advise. Thank you.
RE: Operating near end of curve
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
You should realy post a copy of the curve with your duty point(operating) marked on it - no mis-understanding.
It is not unusual to have BEP towards the "end" of the curve, actually it's not really the end of the performance curve, it's just that the manufacturer has decided not to extend the curve any further to the right as there is really no need, good practice says you should not operate out there anyway.
I've had a couple of these pumps and I remember the rotating equipment engineers were not happy when I showed them were the pumps were running on their curves.
* Fluid
* Pump configuration.
* Number of stages
* Speed (rpm)
* Specific Speed
* Suction Specific Speed
* Suction Energy
It would also be helpful to see the curve.
Given the data that you did provide, there is not an obvious problem. I would not agree that an 8 foot NPSH margin is "considerable", especially if the fluid is water. There is nothing magical about the end of the curve. In some cases, this is just the flow rate where testing was discontinued. Saying that the pumps runs at 108% of BEP is much more telling. We have many pumps that run above BEP by 5 to 10 percent and run quite well. But, if this was a Sundyne running at 21,000 rpm, it could be disastrous. This might result in cavitation within the diffuser throat. If this was a vertical turbine pump with 35 stages, this could be disastrous. This might result in up-thrust, shaft buckling and catastrophic failure. But, if it is an ordinary, horizontal, single stage overhung pump, running at 1800 rpm with a relatively low suction specific speed, it might run well and be trouble free.
We set our limits for maximum flow relative to BEP based on specific speed and suction specific speed. For most services, we allow flows up to 120% of BEP.
Johnny Pellin
If it's 108% of BEP then I wouldn't be concerned if it's a typical horizontal centrifugal pump.
http://files.engineering.com/getfile.aspx?folder=1...
From curve you supplied it looks ok. What is shown is a curve which is drawn only to the duty point, in real-life it would extend further to the right but without having a full performance curve for this impeller diameter it's hard to say exactly what will happen beyond this point for any upset conditions.
Johnny Pellin
The "end of the curve" is more limited by the faster swing to high NPSHR values than anything else. 8% over BEP isn't enough to worry about, as I indicated before, as long as you have that NPSHA.
Recommendation - I would go with the selection based on the information provided, so long as NPSHa>NPSHr. If you have questions, i would contact Goulds Pumps - they are extremely helpful and will sit down and explain the reasons and though process behind it.
Reliability - the statement made previously that the pump wont be reliable is not completely true. Operating well below or past the BEP will produce increased vibration which in turn kills seals and bearing (thus the pump being unreliable). ALTHOUGH, this statement is true based on the Nss of the pump. If you have a low Nss pump (such as you have) the prefered operating region is much wider than if you had a high Nss. This is why it is acceptable to run this pump.
End of Curve - A previous users statement is correct, just because the line stops on a curve doesnt mean that it cant operate past run out flow. The reasons behind this are as follows: NPSHr may go crazy after a certain point so OEM's limit the flow, pump may exceed vibration limits after runout so the flow is limited, efficiencies may plummet after a certain flow, etc.
Selection Criteria - API pump selection criteria is 80%-110% BEP. No questions asked.
Let me know if you have any more questions.
Where generic pump performance curves are being used, I think it is best to presume that operation at or near the ends of the published curves should be avoided whenever possible. The ends of the curves may simply represent the end points of testing, but they can suggest the development of operating or durability problems beyond those points. Usually, the ends of the NPSHr curve is the best guide to the tolerable operating range for a particular pump.
Commonly, the published performance curves are based on a constant, synchronous shaft speed (1800 rpm, 1500 rpm, 3600 rpm, etc.), and the actual installed performance characteristics may vary according to the actual slip of the driving motor. While these effects are typically minor, this may not be a trivial matter when the chosen operating point is close to the ends of the published curves. This is yet another reason that I would want to avoid the selection that you are considering.
Valuable advice from a professor many years ago: First, design for graceful failure. Everything we build will eventually fail, so we must strive to avoid injuries or secondary damage when that failure occurs. Only then can practicality and economics be properly considered.
