Converting CreateNote to Annotations.Note
I am modifying an existing automation. I simply wish to select the note and change its color. Current note creation code reads:
CODE
ufs.Drf.CreateNote( 1, RootLineNote, RootLineNotePt, 1, TheNote )
I wish to change the color using the following code:
CODE -->
Dim displayModification1 As DisplayModification
      displayModification1 = theSession.DisplayManager.NewDisplayModification()
      displayModification1.ApplyToAllFaces = False
      displayModification1.ApplyToOwningParts = False
      displayModification1.NewColor = 108
      Dim objects1(0) As DisplayableObject
      Dim note1 As Annotations.Note = CType(workPart.FindObject("ENTITY 25 25 1"), Annotations.Note)
      objects1(0) = note1
      displayModification1.Apply(objects1)
      displayModification1.Dispose()
I need to get the previously created note set as an Annotations.Note so I can reference it as an object.
Any help would be greatly appreciated.
RE: Converting CreateNote to Annotations.Note
The variable TheNote is the tag of the note object. You can use the ObjectManager to return the object of a given tag.
Try something like this:
CODE
Dim myNote As Annotations.Note
myNote = Utilities.NXObjectManager.Get(TheNote)
www.nxjournaling.com
That worked!
