Cold Weather Spiral
Cold Weather Spiral
I'm tryng to do some research on the use of spiral welded pipe on gas transmission, or gas gathering systems in cold weather climates. I think Canada has the history that I am looking for, but I have yet to find any documentation that would support that theory. Can any of you Canadians come to my rescue? Any pointer to either some public or pay4 info on the net would be just the thing that I'm looking for. With, or concerning, maintenance, integrity and reliability history, even better.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
RE: Cold Weather Spiral
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
But this is all the hard evidence I've found so far.
First use of X80 in North America and spiral as well.
Nova Pipeline Corp. - Eastern Alberta System 1994
Matzhiwn Pipeline 33 (to 54?) km 48" spiral pipe 12 mm WT X80
I know the evidence is out there. I just have to be patient.
David Simpson, PE
