AO Smith Laser Pool/Spa Pump
Hi we have a pool pump for repair as above. its a 2 speed pump which has blown up on the connections. We have managed to pick up some of the leads,and have found 2 pole run winding, what looks like a 2 pole we assume start winding ? and a 4 pole run winding. We have rewound AO Smith 2 speed motors from spas before which have separate run and start windings and separate run capacitors. What is strange about this pump is that it has Run Cap and a Start Cap. If any one could help with a connection or winding diagram or advise that would very much appreciated. The response for information from Century was not very helpful as expected. Pump Details 220-240 volts, 1 phase, BN55, 7-186364-02, Frame y48y, Pump duty 1081/1563
