Rename a Annotated View with script, is not working (DMU Navigator workbench)
I try to rename a annotated view using a small script but is not working as it should.
If I check in the proprieties window of the Ann view, it seems that the name was changed, but in the tree I can see still the old name.
After I click Apply in the proprieties window, the name is also changed in the tree.
Thank you for your help.
CODE -->
Sub CATMain()
    ' Retrieve the AnnotatedViews collection
    Dim cAnnotatedViews As AnyObject
    Set cAnnotatedViews = CATIA.ActiveDocument.Product.GetTechnologicalObject("AnnotatedViews")
	' Retrieve selection
	Dim sel
	set sel=Catia.ActiveDocument.Selection
	' Check if selection is a annotated view
	If sel.Item2(1).Type = "AnnotatedView" Then
		name = sel.Item2(1).Value.Name
	Else
		MsgBox("Select Annotated View!!!")
		Exit Sub
	End If
	' Retrieve selected annotated view
	Dim annView
	Set annView = cAnnotatedViews.Item(name)
	' Change name to a desired one
	annView.Name = "test"
End Sub
RE: Rename a Annotated View with script, is not working (DMU Navigator workbench)
Can you try to force update the view ?
I didn't test but something like:
Set oSelection = catia.activedocument.Selection
oSelection.Clear
oSelection.Add annViewUpdate
Fernando
https://picasaweb.google.com/102257836106335725208
Thank you for your answer.
It's not working, but I succeed by unlinking and linking the annotated view.
